I have a bunch of old VHS home movies that I want to transfer to digital format. What's the best way to do this?
Will a simple sony DVD recorder be the best way?
Really? All I need is that little adapter? Can I use other software to capture other than what comes with the device?
Is the quality any different from other devices. This is what has me confused, what's the difference between an inexpensive device like this compared to the more expensive ones as far as capabilities and video capture quality.
I know its been a while but I've been busy transferring from vhs to avi. I purchased the Canopus ADVC 110.
Now my next question, I want to burn these to a BD since there's more space than a DVD. What format am I converting it to so I can play it on my BD player?
thanks again
