I currently have a tower case that will hold 20 3.5" drives. Though I do not have 20 drives it is something I would like to work towards. However I'm trying to figure out the best way to hook them up. I've been looking at the Megaraid cards from LSI and have found an 8 port card for about $140. I believe this is a slightly older card but I'm putting this together for home use so that's not a huge issue. However, when searching around I ran into SATA Port Multipliers. From what I am reading these allow you to run up to 5 drives off of a single SATA port. I realize that a single SATA port has 300 MBPS bandwith and a standard drive can use up to 90 MBPS of that so there may be a bottle neck there. However if I could put together something for significantly less money it may be a better option.
What do you guys think?
