A paper towel? I haven't ever found a need to use a liquid to remove paste, A micro fiber rag will clean it to a shine.
Some thermal paste can be very stubborn.
This is true.
Oh also, when in your first electronics class and working on a stick vacuum, don't grab the tub of hs compound and use it to lube the bearings on the motor.
Bad bad things happen.
Roflcopter.
I just grab the q-tips and the wife's fingernail paint remover. Works great.
99% Isopropyl alc, can be found anywhere really, i just picked up a bottle from Safeway. And also get coffee filters and use those, they work perfectly and are lintless
Salon fingernail polish remover. Don't get that pure 100% acetone stuff, get the watered down one or the pure acetone will melt right through the motherboard if you drip any on the plastic. Then clean it up with some 99% alcohol to help dry it off.
Also Goo-Gone works well, which is basically what Arctic Silver Thermal Paste Remover is made of, citrus extract.
