bagelnagel
- Mar 2, 2013
So I'm in the process of planning out my next major build and I saw that there now exists the possibility of using an AIO cooling unit (i.e. H60) to cool video cards. I'm interested in this for noise reasons... and why not? Also, if I decide to really splurge and build a HTPC outside of my main rig, I believe that AIO cooling would be beneficial in a smaller enclosure. So, to get more knowledge, I'm turning to the big [H]:
Anyone have this setup? Any advice, warnings? Looking back, do you think you would do it again?
Which card would you recommend using? I would like to either get a 7970 or 680, as this would be a setup that I'd have for at least 2-3 years. Since I'm going to be taking off the coolers that comes with the card, I wouldn't need any Vapor-X/DCII frills. That could change which card is recommended.
If I'm operating under any incorrect assumptions, please, by all means, correct my ignorant self! Thank you in advance!
