Was looking around and didn't find much on Trojanware, Spyware, or Malware cleaners. I'm trying to salvage a computer before I perform a clean install. This computer is not mine, I don't have the software, I didn't want to fix it, but it was forced on me. Its full of everything and anything as far as malware, spyware, and trojanware are concerned. What is the best way to clean? Or what scanners should I be using?
I've used Spybot, Adaware, SuperAntiSpyware, AntVir, and Norton. But, there are still stuff on it. I don't want to waste my life away finding specific trojanware fixes either..is there a generic scanner that will look for all sorts of trojanware, rather than a specific type?
Like I said, this computer it no mine, I wanna get rid of if as fast and easy as possibly, minus a clean install (I don't have software or XP key for it)..
Thanks
Thanks
