It seems the AUO MVA screens are not as good as the PVA screens.... My TV is a Sony/Samsung SPVA screen and it has no glow at all and the blacks are good... Is there not anything like this in 24/27" pc monitors? PVA instead of MVA? or are they all AUO MVA these days? As it is made by Samsung I think they still make their own panels (instead of AUO)?
This one looks good in the pictures... http://wecravegamestoo.com/forums/m...0p-review-1920x1080-72hz-semi-glossy-mva.html But then most of the screens in those reviews look good (very saturated with good blacks even on the IPS screens) so maybe it is the camera?
You're likely using your TV from a distance to which it doesn't suffer from obvious head-on gamma shift. Sitting further away, as I said, will alleviate the issue entirely. A lot of the issues I had with the BL3200PT was also due to the fact that I was using it slightly off angle (this added more obvious glow due to gamma-shift/poor viewing angles.)
I will never understand the obsession with VA panels for computer monitors when gamma-shift is still a rampant issue. Proper room lighting + a bias light makes the contrast difference between VA and IPS panels entirely negligible and helps alleviate IPS glow.
