I wish I WAS a turtle.I like turtles.
People who seemingly don't even know how to module.h properly are always telling me that Linux is the best OS to use, but I've always had my best experiences on Windows 8.1, so that's what I recommend.
I run IRIX.
Thanks guys, for delivering EXACTLY the thread I expected to see after reading the initial post.![]()
Windows 10: From playing with the technical previews - yes, it will be worth going to. Free upgrade for Windows 7 & 8 users. So, if you buy now you can upgrade later.
I just built a new computer last night and installed the W10 preview on it. Was a total pain trying to get the Battlelog plugin to work. Chrome didn't work with it at all and IE required several tries and only a reboot later it started working.
Judging from that it's probably not going to be just smooth sailing yet - or possibly ever.
Wow. You had some issues there. Definitely not the norm, though. For me and many others, Chrome and IE work excellent. Battlelog, I can see... I've had a couple things stop working for me, too, with the latest build. After a couple fixes or a reinstall, they work fine. Still, pre-release software, though.
Well I think my plan is to use windows 10 when I can get it. Is it just an upgrade or do u get windows 10 and can install it where ever?
EWWWW. I worked on a machine from the early 90's that had AIX on it... huge piece of turd is what it was.
