loafer87gt
- Feb 2, 2005
I am putting together a new Kentsfield / 8800 GTX build this weekend and am having a hard time decidig which PSU to go for. The three I have shortlisted right now are the Enermax Galaxy 1000 (seems a bit overkill, and most expensive at $349 CDN), the Silvertone Zeus 750 (not modular, but seems to get quite good revivews and is priced at $218 CDN), and the last is the Corsair 620HSX (modular, Seasonic guts, and well priced at $165 CDN). Using the Extreme Power Supply Caculator it said that my current build would drawing max 537 watts. This is what I plan on having in the machine:
1 x 150 GB Raptor
2 x 320 Seagate SATA Drives
3 x 120 MM Fans
1 x Evga 8800 GTX
Kentsfield OC'd to ~3.00 at maximum 1.4 V
Pioneer DVD
Floppy
Dell 2405 display
What do you guys think I should go for? The Corsair sounds nice, but I can't help but feel the 620W might be pushing it a little. Is there any other quality modular PSU's I should be looking at that would work well for my application?
Any advice would be mucho appreciated.
Thanks
1 x 150 GB Raptor
3 x 120 MM Fans
1 x Evga 8800 GTX
Pioneer DVD
Floppy
Dell 2405 display
Thanks
