Best mobo for the price to overclock a 9600k or 9700k
Discussion in 'Intel MoBos' started by Ragenrok, Jan 31, 2019.
  1. Ragenrok
    Ragenrok 2[H]4U
    3,946
    May 15, 2007
    My poor 4670k just died and I'm planning the upgrade now. I'm still torn between the 8600k/8700k/9600/9700k but what I can nail down for now is the mobo I want to aim for but I have been so out of the loop I have no idea where to look.
    Budget is a big factor for me, my main goal is over clocking to hopefully 5ghz or higher using my custom wc loop. I have very little need for fluff features like wifi, Bluetooth or high end integrated sound as I hardwire my PC in and use a receiver so HDMI does all my audio. The biggest factor is good power distribution for steady high overclocks, but if it's the difference of a $100 I'll sacrifice the potential for that last 1-2ghz of OC lol.
    Keeping price in mind what's some good choices? Build will be 95% gaming if that makes a difference with zero interest in workstation or streaming.
  2. Colonel Sanders
    Colonel Sanders 2[H]4U
    3,725
    Sep 26, 2001
    If you are looking at Z390 boards, the Gigabyte Z390 Aorus Pro has a great VRM for the price point, better than most if not all the competition at its price point.
    revenant and Ragenrok like this.
  3. Ragenrok
    Ragenrok 2[H]4U
    3,946
    May 15, 2007
    That was the one I was eyeing up lol, just read some more reviews and I think it's exactly what i was looking for, thanks!
    Colonel Sanders likes this.
  4. Colonel Sanders
    3,725
    Sep 26, 2001
    No prob!
  5. revenant
    revenant [H]ardForum Junkie
    14,076
    Apr 10, 2005
    Yeah I was shopping Z390 boards recently and it seems like Gigabyte variants are pretty beefy with at least a 12+1 digital vrm config which should work nicely with these 9th gen cpus. When I am ready to pull the trigger I am looking at the master with 12+2 phase IR and a sabre dac for audio. At the price point I think the Pro is for sure the best also.
  6. Ragenrok
    Ragenrok 2[H]4U
    3,946
    May 15, 2007
    I actually just finished building my new rig, grabbed the aorus pro and a 9600k and it's awesome so far. 9600k is running at 5ghz easy and stable, games run so much better on this new CPU lol
    revenant likes this.
