dvsman
- Dec 2, 2009
I've used a Das Keyboard for my office keyboard for the past few years (10-12 hour days on the computer/typing) and definitely recommend that for typists / work. It has 2 usb 2.0 on the side that work fine in a pinch, for the random mice / jump drives. My only complaint is minor - the LED they use to light the caps / numlock above the number pad is very weak and barely legible in standard office lighting.
At home I'm using a Max Keyboard Nighthawk X8, also great. It has bright fixed single color backlighting, audio in and out and 2x US 2.0 as well (on the back side, facing away from the user, above the keypad).
I'm sure the newer, latest versions of either keyboard are still great.
Aside from that, I just ordered a Logitech G910 Orion Spectrum (from the Best Buy deal someone posted on here) to try out the Romer-G switches. This will be my first non-Cherry MX mechanical caps and switches, so curious to see what the differences might be.
