Best? Or most overkill?
Probably the Maximus VII Gene
http://www.asus.com/Motherboards/MAXIMUS_VII_GENE/
Gigabyte what?Gigabyte or Asus Gene.
Gigabyte what?
I am looking at mini-itx boards but I was curious about mATX as well. But, I noticed that mATX don't have built-in wifi. Do they have a slot to put in a wifi card? Will it be worse or better than integrated ones in mITX boards?
Lol, either or
I was waffling between this and the Gigabyte Gaming 5. The Gigabyte is around 80 cheaper too.
Gigabyte what?
Sorry, what's the difference between a 8 and 4 phase?
I do plan to SLI 780s or 780tis
Mini-itx version, too, probably? . If price is no object, I would get the mini-ITX gene. It has all the hardware specs I want. Problem is, it's over $200!maximus gene is a great mATX
