I need a laptop under $600 with 4hr+ battery life.
The best option I found is a Dell 1501 configured as follows...
15.4 inch Wide Screen XGA display (glossy)
Turion MK-36
1GB DDR2 at 533MHz
80GB 5400RPM Hard Drive
24X CD Burner/DVD Combo Drive
ATI RADEON Xpress1150 256MB HyperMemory (Integrated)
Dell 1390 802.11g mini card
85 WHr 9-cell Lithium Ion Battery
$589
I found the problem with buying in a store is that the laptops never come with a high capacity battery, you have to buy one seperately for another $150. So I guess I have to order online.
Do you guys know any other companies that can even approach this price? I found a laptop with similar specs from HP (v6000t), but it was $20 more and the 12 cell battery sticks out the bottom of that one, which might be odd.
Thanks for the help.
Turion MK-36
1GB DDR2 at 533MHz
$589
