tiebird321
- Jun 6, 2004
i'm looking at buying either the panasonic UJ-825-B
http://www.newegg.com/app/ViewProductDesc.asp?description=27-133-004&depa=1
or the toshiba SD-R6372K
http://store.yahoo.com/directron/sdr6372k.html
they are within $3 after shipping
i sorta want a nec 6500 but its almost $50 more
the thing i care about most is media compatability when using the drives with princo and some other cheaper dvd-r media
i only do 1 or 2 dvd+r disk's a month so i dont mind if i have to use more expensive +r disks
but i burn about 50-70 dvd-r disks per month so media compatability is a must
Thanks for the help
Thanks for the help
