Hi guys
I will let you know my rig to get it out the way and also help you recommend a monitor to suit it. I have a EVGA Nvidia GeForce GTX 760 Superclocked 2GB GDDR5 Graphics Card, an i7-2700 with 16gb of DDR3 ram, An Asus RAMPAGE motherboard and a H100i cooler. Think that's all you need to know. If you want to know more just ask.
Anyway to the monitor. I am going to be using this monitor for photo editing so I'm am looking for an IPS monitor but when I am not photo editing I will be gaming.
So I am looking for an IPS monitor from 23inch to 27inch. Now I want the best colour reproduction but also a nice low input lag for when I game. I will also be watching movies from time to time. Now I may be asking a lot here because my budget is quite low. The maximum I have to spend is £350 which is $533.
I have been doing my research and have found some possibilities like the BenQ BL2710PT which is £9 over budget but I think I can Handle that. I have also had a little look at the Korean monitors out there but I am very weary of buying them mainly because of dead pixels. I know you can get the pixel perfect guarantee but pay the price for it. I have also been told they can be overclocked to make them 120hz.
Question. How do you overclock a screen? Would it be worth it with my gpu?
Another screen I have looked at was the asus mx279h but this is only a 1080p monitor at 27inch so I'm sure the pixel density will be rubbish. There is a 23inch version of this screen but cannot find a review for this version.
So to sum up
IPS monitor
Max £350
23-27 inch
Low input lag
Good colour
All recommendations are welcome
So to sum up
IPS monitor
Max £350
23-27 inch
Low input lag
Good colour
