Delicieuxz
- May 11, 2016
Which fans do you like most for intake, exhaust, and on a CPU cooler?
My air cooler is a Noctua NH-D15, and I have three NF-A15 fans I can put on it. Is there a better choice than those?
I'm thinking of replacing my case's Be Quiet Pure Wings 2 fans with 140mm Silent Wings 4 PWM high-speed fans, having 3 intake and 2 exhaust. Would the Silent Wings 4 be a good choice for exhaust fans, when silence is my priority, with cooling performance also being important, or would something else be better?
A post here mentions they got the non high-speed (1,100 max RPM) 140mm Silent Wings 4 and used it as an exhaust fan, and it didn't work that well. While I think my case's 140mm Pure Wings 2 fans top out at 1,000 RPM (I'm unsure if the exhaust fan would be the 1,600 RPM high-speed version).
Tech Power Up's benchmarks here suggest that at lower RPM, the Silent Wings 4 doesn't push as much air as a lot of other fans, but at 1,000-and-up RPM, it pushes more air than most, while still being quieter than most.
Igor's Lab has some good comparison charts for fans, and makes Silent Wings 4 look much quieter than Pure Wings 2.
