I have a bunch of MP3s that I'd like to retag and rename in a batch. Does anyone know of a fast and accurate renamer/tagger? I've been using Musicbrainz and it works great but it isn't exactly quick.
I think his problem is that he has individual songs, NOT albums, with incomplete ID3 tags that he wants a program to be able to guess the correct ID3 tags to update the files with.
Thanks everyone. I didn't really like Tag & Rename (and uninstalled it and can't remember my reason for not liking it).
I've been using CDTag and it has been working great. A lot of my albums had good ID3 tags but the naming convention was not like I like it now. This fixed the naming and updated any ID3 info.
I use MusicBrainz. This is THE BEST!!! as it listens to your music and then tags it and even renames the file to any way you want... TRUELY THE GREATEST!!!
another vote for the godfather. make sure you get and use the amd patch. nothing like having a folder of an album, using the built in browser, and viola!, you have the mp3s tagged with everything known (and my xbox likes album art)
