dandragonrage
- Jun 5, 2004
The "CRT noise" has absolutely nothing to do with a 60Hz refresh rate. It has to do with noise powering flyback transformers.
Wrong - pixel clock affects the noise as well. In NTSC CRT TVs the noise is fixed at the NTSC horizontal pilot frequency of 15,734Hz. With CRT monitors, it varies depending on the pixel clock.
Don't correct people when you don't know what you're talking about. Thanks.
Also I do see flicker in many fluorescent bulbs, but you're also wrong about 60Hz AC frequency being the only factor. In monitors, different phosphor types can "store" the image for different amounts of time. TVs typically used long-lasting phosphor to reduce flicker while PC monitors used shorter duration phosphor to support higher refresh rates (making lower rates suffer more flicker) and even then it varies by brand and model. Different types of fluorescent bulbs and ballasts can affect the amount of flicker seen, too. The 60Hz AC frequency is only one factor.
Again, don't correct people when you don't know what you're talking about. You won't find any holes in anything I've said in this thread, anyway.
