Best gpu I can run within my itx build?
Discussion in 'Video Cards' started by Jbort1984, Aug 2, 2019.
  1. Jbort1984
    Jbort1984 [H]ard|Gawd
    1,204
    May 28, 2009
    So im stuck at a stand still on my itx build wanna know what the best bang for my buck gpu is my specs are as follows
    I7-6700 non K
    16gb corsair vengence pc 2400
    1tb evo plus m.2 ssd
    2x4tb storage drives
    Asus H170I Pro itx mobo
    FSP Dagger 500watt full modular psu
    My choices so far have been a Gtx 1660, Rtx 2060, Vega 56
    Case is a Lian Li pc-Q30x
  2. Criticalhitkoala
    Criticalhitkoala [H]ard|Gawd
    1,670
    Apr 17, 2015
    2060 would be best imho. Can't speak for Vega, but the 2060 is pretty fast. 2060 Super is better.
    AceGoober likes this.
  3. Jbort1984
    1,204
    May 28, 2009
    I was thinking the same thank you
  4. honegod
    honegod [H]ardness Supreme
    6,556
    Aug 31, 2000
    Your case
    Graphics Card: Up to 200 mm Length and 125 mm Height (Including Power Connectors)
    I searched newegg for a 2060 or 2060S
    Under 200mm 0 hits
    Zotac minis are 210mm long, but the board looks to be full length making modding it 10mm shorter NON trivial.
  5. Dayaks
    Dayaks [H]ardness Supreme
    6,928
    Feb 22, 2012
    Can you cut any pieces of the case out to fit a larger card? I do it all the time...
  6. rhansen5_99
    rhansen5_99 [H]ard|Gawd
    1,995
    Nov 12, 2001
  7. honegod
    6,556
    Aug 31, 2000
    ASUS TUF Gaming GeForce RTX 2060 6GB Edition 4K VR Ready HDMI 2.0b DP 1.4 Auto Extreme Graphics Card (TUF-RTX2060-O6G-GAMING)
    204mm
  8. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,772
    Dec 23, 2001
    Ditch the case.... That thing is weird and fuggy. Even the 1070/TI mini by Zotac is 211mm
