enyceexdanny
- Sep 22, 2003
Hey guys. I'm currently using 2 x Scythe F Fans to push through the radiator. I wanted to improve my temps as current OC temps of my i7 920 is pretty high at ~45 idle/~80 load (211 x 19). I realized that the easiest would be to replace the fans.
Which fans would you recommend for my radiator that has high static air pressure?
It seems the Gentle Typhoon AP-15 fairs pretty well, but I would like your opinions.
Thanks.
Thanks.
