The Super-7's were trash.
AGP compatibility problems and a host of other issues.
Mainly shitty drivers.
On it's best day I hated the Super 7's.
Let's not forget it was home to the worst motherboard of all time. The FIC VA503+.
#1 8088
This CPU makes the top spot only because it was the first to use the x86 instruction set. Although this instruction set is hardly the same anymore, it's influence is still present in today's microprocessors. This instruction set remains firmly entrenched and has been for the last three decades. There is no signs of it going away anytime soon either.
Celeron 300A still one of my favs. Dual C300A goodness for a lot of fun, and pain, if you know what I mean when dealing with Tyan dual socket offerings.
Although I've never owned one, my vote goes to the Q6600. If I could go back in time to when they first came out, I'd just fork out the extra initial cash and I'd probably have saved money over the 2 or 3 AMD platforms I've had since.
Let's go down the list of why you are wrong about what you listed relative to what I posted:
Had nothing to do with the socket or the bus but rather shitty VIA and SIS implementations.
Nothing to do with the hardware.
Nothing to do with the socket or bus.
One bad VIA board.
Really Dan? Super Socket 7 was a brilliant solution to a problem that would have killed AMD and none of your points had anything to do with Super Socket 7. What you should have said is "I hated VIA chipsets in 1998/1999" at least that would have been accurate. You will also notice I said under-appreciated, which it was and you demonstrated very nicely with your off the mark dislike of VIA not the processor or socket.
Well, there are others I think are good, but I have to admit that 939 dualcore cpu's were the best.
reason, they were the first to have proper dual core support as said earlier in the thread, plus even now, 5 years on, the high end 939 chips are still great chips for pc's.
I have had 3800 4400 4800 and fx60, the 48 and fx60 can play all the latest games, and windows is still uber fast, ok some games can be a struggle, but with proper tweaking they play perfectly.
So I would have to say that they are my numero uno chip's. Although there are more worthy chips from years earlier and years later, but the x2's are my fav's.
What's funny is that you guys keep talking about the Pentium 90. I've seen very, very few of them. I've seen more Pentium 75's and Pentium 100's than I ever did the 90's.
The Q6600. Why? Because it has lasted me longer than any CPU I've owned before.
Your right, I should have worded my post differently.
It wasn't the socket itself that was trash. It was every chipset that used it that was shit. That is very much at the core of why the platform sucked. Yeah it kept AMD afloat during a turbulent time, and the platform as a whole saw some moderate success due to being relatively inexpensive and compatible with older Intel Pentium MMX CPUs. As for the CPU it was amazing in that it was really good given the outdated platform and bad chipsets those CPUs were paired with. Still it wasn't a match for the Pentium II and like the Phenom / Phenom II's of today the only thing it really has going for it is price.
"Proper" dual core support is really a BS argument. While I'll agree that the solution was far more elegant than the dual die's shoved into one package that Intel used, the approach alone didn't matter. The Core 2 Quad's were dual core CPUs with properly integrated dies sandwiched together. Those Core 2 Quad's absolutely raped the more elegant Phenom processors which were a more "proper" setup. So where the rubber meets the road the "native" or "proper" approach doesn't mean a damn thing and it never did.
My favorite processor setup was dual Pentium III 600's (the 100MHz FSB version) on an ABIT VP6 mobo. Easy bump to 133FSB @ stock voltage. Never could get them past that point, though. Anyone remember Golden Orb HSFs?
