best chair under $100?
Discussion in 'Gaming & Office Furniture' started by Gabe3, Mar 15, 2018.
  1. Gabe3
    Gabe3 2[H]4U
    2,884
    May 23, 2006
    this sealy chair I have is at the end of its life. I could probably buy the cheapest chair on amazon and it would be better, and those are around 50, but I figured I'd ask first to see what is recommend. I just had lower back surgery so something with lumbar support is probably a good idea. besides that, adjustable arm rests would be nice. I don't really know if I should get a "gaming chair" or a office chair. I game but not really sure if thats a reason to get one.
  2. Gabe3
    Gabe3 2[H]4U
    2,884
    May 23, 2006
    I got this one a couple days ago from staples: https://www.staples.com/staples-hazen-mesh-task-chair/product_1058246
    its on sale now for $95. it has great back support. the floor model tried out in the store was a early revision, because the one I got out of the box had a firmer seat and smoother arm rests, both which I wanted.
    it has 4.5 rating on staples with 570 reviews. but the staples website is a POS and only shows the reviews on the mobile version for this chair.
    the hyken model is another popular one, I was split between the two. theres a little less back support on the hyken. and I was unsure about a mesh seat. I didn't like the plastic mesh all that much. the hazen has cloth mesh.
  3. sanders4617
    sanders4617 [H]Lite
    114
    Jul 16, 2009
    Thanks Gabe, also going to check that one out. I need one bad!
    Gabe3 likes this.
  4. margrave
    margrave [H]Lite
    118
    Feb 15, 2018
    The term "chair for under $100" and the word "best" don't belong in the same sentence.
    Under $100 is junk.
    You might find a good one on sale for under $200, but mostly you need to spend over $200 for a good one ... especially if you have back and posture issues.
    No more cheap chairs for me.
  5. Nenu
    Nenu [H]ardened
    18,366
    Apr 28, 2007
    Spend $100 on some large feather cushions for your sofa and game from there.
  6. Hofy
    Hofy 2[H]4U
    2,373
    Jun 3, 2004
    Go $150 and buy a used Steelcase Leap.
  7. 0107sj
    0107sj n00b
    2
    May 2, 2018
    If you are not really sure if you should get an office chair or a gaming chair you are probably better off with a regular office chair. Amazon has some pretty fantastic ones for around 100 dollars. Whereas proper gaming chairs usually require atleast 150dollars. I can recommend the office chair listed under budget options here: https://www.progamerreview.com/best-gaming-chair/ and if not then the kinsal https://www.amazon.com/Kinsal-Ergon...ie-20&linkId=54261e4d50cd44aa21f4b67c78ac631e which is probably the best gaming chair for around 100 dollars, but it does go a bit above it. Btw, new to the forum, came here to learn about windows 10 optimization, dunno if I am allowed to link yet, if not, I apologize.
  8. HiryuuX
    HiryuuX Limp Gawd
    206
    Jul 16, 2017
    I'd aim for a non-gamer oriented chair, like an Ikea Markus or used Steelcase/Herman Miller chair but you may have to up your budget to $200+.
  9. George Chuvalo
    George Chuvalo n00b
    6
    Jun 15, 2017
    I had an IKEA Markus and I would not recommend it. The cloth fabric they use for the seat is too slippery and I always slide into a bad posture.
  10. Lumpus
    Lumpus Limp Gawd
    213
    Sep 2, 2005
    I've gone through 5+ "Office Chairs" in the last ten or so years, until I just gave up on them.
    You'll laugh, but the best computer chair I've ever had in my life was actually a 'sewing chair' - bought at a local sewing machine dealer. It's about three years old (bought as a showroom sample)... but just as good now as when new. When it goes I'll buy another exactly like it.
    It's the same egonomic principle (sewing/gaming sitting)... sturdy + back and butt support for sitting hunched over for hours at a time.
    ItWasMe likes this.
