sirmonkey1985
[H]ard|DCer of the Month - July 2010
- Sep 13, 2008
Can you de mount the arm rest on this chair or are they needed to support the back of the chair ?
you can but i wouldn't recommend it.. the only thing supporting the back is 4 bolts on the steel plate that attaches the back to the bottom of the chair.. it's not thick enough or bent in any way to support you sitting in it without the arms attached to the side of the chair.. as far as the model with the adjustable arm rests i don't know how the base is designed for that.. either way i'd leave them connected, the back of the chair isn't as straight as people have claimed. at first the mechinism to lean back is really stiff but after having the chair for a little over a month it's perfect now.
wow, i have almost exactly the same chair and it's been the best chair i ever owned, i want another, i will keep watching.....
hopefully tomorrow, it will drop....
thanks to the OP for the post!
it randomly goes on sale and never for the same price as the previous one.. the original was 140'ish then 160 then 189. you just have to check their website periodically and hope you get lucky.. i paid 160 before taxes for mine.
