Best cases for MPB 13in?
What is the consensus on the best cases for MBP? I'm looking for the cases and not sleeves. Form fitting kinda stuff. I looked over the brands that are on the apple site and etc and there were a lot of bad reviews on speck and incase stuff so I don't know. Any opinions? Moshi any good?
mope54
The Speck ones seem to be the best from my experience. My partner uses a speck on her mba that feels kind of rubberized. I prefer no case at all.
d4nnn
I use Incipio cases, the feather weight ones. Best ones I've had.
DenverBarr
Problem with the speck i have (seems like your partner has the same) is that dust and dirt gets underneath it and can scratch or make it dirty(happend to me) so now i don't use a case.
mope54
bestskinsever also has a macbook protective layer that is made from the phone protectors they sell
I put one of them on my ex's macbook and it turned out nicely
