Another vote for the crossfade m-100's with upgraded memory foam ear pads.
+1 I have a dedicated pair for use at work plugged into an Onkyo TX-SR606 (overkill, but I had a spare around), fed by S/PDIF from DP.just bought some Denon AH-D600's and they are bassy and sound great. They used to be $400+ but they were recently discontinued and I got a new pair for $279.
That is one amazing way to escape the world while working!+1 I have a dedicated pair for use at work plugged into an Onkyo TX-SR606 (overkill, but I had a spare around), fed by S/PDIF from DP.
Pure audio bliss in the cube farm
I just bought a Schiit Asgard 2 to pair with my D600's, interested to see what kind of difference it will make with a lower impedence set of cans like the Denons+1 I have a dedicated pair for use at work plugged into an Onkyo TX-SR606 (overkill, but I had a spare around), fed by S/PDIF from DP.
Everyone says Bayerdynamics tend to be bass heavy without being shit from what I've seen, so that's the route I'd go.
I would like to recommend Sennheiser, No compromise over quality.
No compromise my a*s. The Momentum cups are uncomfortable for anyone who doesn't have dwarf ears, and I'm talking about the over-ear models, even the 2.0.I would like to recommend Sennheiser, No compromise over quality.
You cant go wrong with the Sony MDRXB800 Extra Bass Over-Ear!
