Thanks!
I've always used monitors with at least 5 ms. This one is 8 ms. Will the difference be huge?
There is a " Fast " mode that brings it down to 5ms...I really can't tell the difference in actual use though. I don't notice any lag in the normal mode.Thanks!
Could have had either the Crossover 34U100, or Microboard M340clz for $700. Both are 100Hz with freesync.
I think for the same or less $, plus a curve and a 60% jump is refresh rate, buying Korean is worth the very slight warranty risk.Well, the OP has a 1070, so freesync is useless in his case.
Personally I'll take the Dell Ultrasharp warranty over either one of those two brands any day.
