SilverSliver
- Feb 23, 2004
I'm leaning towards the Korean offerings, this will be business use only so 120hz is not needed. Not sure which one is more suited for that. Thanks for the help.
The True 10 uses LED PWM Dimming (Side Effects), get a Crossover 27QW DP or 2720MDP. The 27QW DP is slightly better than the Crossover 2755AMG. I don't know if the re-brands (First FS270YF and Yamakasi DS270 HDMI) have proper brightness controls. The new Korean AH-IPS use Plasma Deposition Coating.
I thought they use the same panel as Benq and it does not have PWM dimming based on your review. Am confused.
Saw Asus PB278Q for 499. By the time I purchase a $400 monitor and then add sq trade I get close to Asus. How is the Asus one compared to these monitors?
Am looking for photo editing monitor with multiple inputs.
I did get the Qnix 2710 DVI. I loved it but it had a defect and I returned it. Now I am looking for a multi input one. Any input would be great
Do the Korean mulit input monitors support 2560x1440 over HDMI?
Does Crossover 27QW DP or 2720MDP have plasma deposition coating?
Also how about the qnix multiport. The one with Samsung panel. Does it have PWM dimming?
