Hi there! I have an Antec P193 hosting a 580GTX in tri-SLI.
I have a custom venting solution with 120mm flexi tubing connected to the 120mm rear vent in my case spitting the hot air in the case out the rear vent. The 3 580 GTX's run incredibly hot - usually something like 88-92c load each, causing my home office to heat up dramatically regardless of my venting situation. I'd like to put an aftermarket cooler on similar to the Accelero XTREME Plus II solutions (to spit the hot air into the case to be vented out the back flexi-tubing instead of venting out the rear), but in my case it has to be a 2-slot solution since I cannot use a 3-slot cooler like the Accelero XTREME Plus II with a tri-SLI configuration.
Any recommendations if I want to do this project with air?
