TheCommander
- Apr 2, 2003
I'm looking for something with good airflow that is quiet.
Gentle Typhoon? Really, there are a lot of choices nowadays. Maybe check out Silent PC Review?
This. Good airflow, quiet, and extremely reliable.My second choise are the Scythe S-Flex 1200RPM.
Instead of making another best case fan thread, I will hijack this one.
Any recommendations on 140mm case fans? I need 3 to replace the stock ones that come with the Lian Li PC-k58W. It seems like there isn't many reviews on 140mm fans.
I'm looking at these:
http://www.svc.com/fan-nt-140mm.html
http://www.svc.com/blue-vortex-14.html
http://www.svc.com/tr-x-silent-140.html
I'm not too sure about the first 2, the Thermalright seems to be the best out of the bunch.
http://www.xbitlabs.com/articles/coolers/display/140mm-fan-roundup.htmlThat's a tough call. I avoid anything from NZXT thanks to prior experience using their stuff. That one is too loud anyway
I like the second fan you linked, but the thought of using a sleeve bearing is "meh..."
Last fan is "okay" but still louder than what I want.
If I had to choose from the 3 listed, I'd go with #2
Panaflo 120x38mm mid speeds. Use a controller. Done. Best fan there is.
