Nuked my other post to keep discussion in this thread.
Mine doesn't do this... I just woke it up before writing that last post.
You sure it's not an issue with OSX/Mac?
Mine doesn't do it either.
Do you guys have Windows? The BenQ rep said it applies to Windows and Mac.
Windows 7 here. Haven't tried on OS X Yosemite. Maybe I will try it later.
You have both the BenQ 32" and the Philips 40", correct? Which one do you prefer?
Weird, i don't see that issues, really (and others reported)
You do have this monitor? or BL3200PT?
What Mac are you using?
Mac Pro (late 2013)
Dual AMD FirePro D500 with 3GB GDDR5
I just hooked it up to my Air, ran it at 2560x1440, and it doesn't do it...
Yes. Both have their pros and cons.
Philips:
+ Good blacks
+ Glossy / No grainy AG coating
- Contrast shift
- The size. 40" inch feels a bit big on the desktop.
- PWM. I thought I did not suffer from PWM issues but after having used the Benq I can tell that the Benq feels better for the eyes, so maybe I do suffer from PWM issues after all.
Benq:
+ Size. After having used 32" for a few days, I can tell that it feels better to have it on the desk then a 40" inch. I don't have to move the head so much and at the same time text on the Benq is not much smaller comparing to Philips at 100% scaling.
+ Flicker free. It has several "Low Blue Light" modes unlike Philips.
- AHVA Glow / BLB
- Grainy coating, although not so much grainy as some other panels.
Not sure if your corner is brighter than mine or you're just able to photograph it. The lower left is perfectly normal in that picture and my upper corners look like that. The yellow on my lower right is not that bright. Was this at 100% brightness?
Well this is really weird. Can you run it at full resolution, use the scaling feature (choose middle option), and try again (i.e., put to sleep and wake up)?
As its getting darker here, i used brightens 70% - turned off lights, used full screen black background and that yellowish was still there.
I really think i should give another Monitor a try.
Funny, I deduced most of the pros and cons already from reading your posts but that's a nice summary for anyone who hasn't been following.
I guess the question should have been, if you could only keep one and were forced to send one back tomorrow, which one would you keep?
I'm surprised that the text on the BenQ doesn't seem a lot smaller than the text on the Philips. When I compared the pictures that you and others took of windows on the desktop, the text on the Philips seemed much larger and more readable. I realize that looking at pictures isn't like sitting in front of them, though.
I, like you, considered myself to not be affected by PWM. Maybe the effects of PWM are more pronounced on larger screens? Or maybe it's because you've been using them back and forth so closely to one another which makes the PWM effects more evident. My Samsung 27" 120hz monitor used PWM but I was never directly comparing it to another display. I had my Dell 30" adjacent to it, but rarely went back and forth between the two as it was powered off most of the time.
BTW, thank you for your first-hand information on these monitors. It has been very helpful to people like me who are considering both units.
Yep, no dice. Can't use full resolution on an Air.
Also an FYI, the last nVidia WHQL drivers included the 344.80 hotfix that changes how DP 1.2 devices are woken up.
It's up to what satisfies you in the end. To me 70% is very, very bright. I use 30%. I use 20-25% with lights off. Using LG's 34UM95 next to it at similar brightness, the 34UM95 bleed is much, much worse.
Every IPS variant display I've seen does not display pure black with all lights off, including CCFLs.
VA has the gamma shift in the corners unless you have the display pushed back far enough, and TN does something similar.
You're going to need to pick between glow/BLB and gamma shift man.
My Philips has some issues, and I'm gonna return it. That's why I bought the Benq.
For those wondering about 4k performance at this point in time, wonder no more. Here's my rig running BF4 64-player multi on a demanding map as an example including settings pictured:
That's pretty much how most games look in terms of performance/settings for me . Dial things down and drop MSAA and you could get acceptable performance on a single card, I'd imagine... but those claiming that 4K gaming isn't doable with eyecandy cranked are wrong .
Thank you! - reviewing it now.
One more thing i am unable to figure out.
I enabled eye protect setting in OSD, and for some reason, in the right bottom corner there is an icon (pretty big) with eye and some lines under it, it never goes away - how do i remove it, or it is supposed to be there while this option is enabled? (which i doubt).
Thanks guys!
I think it's an inch shorter and two inches wider than a U3014.
Titan should be fine since it has DP 1.2.
