lol just made an account to post this....
I also have this monitor and have had cold hard evidence of my split-second glitch artifacting too, at first I thought it was to do with my graphics card, but if that was the case, why would it affect it when I connect to my laptop as well? So that's rule out, then I thought, maybe it's the shitty cables they've given, so I tried another cable that I know also works on another monitor and still same issue.....so not a cable problem.....so I thought...okay.....maybe it's the connection interface that's fucked up....so I changed from HDMI to DP, and from that to DVI and tried all the other duplicate ports too.....they all seem to show the same symptom...so I thought...ok, maybe the interface connections busted up somehow....or my computer's interface is busted up....but if that was the case, wouldn't the same issue be present on the other monitors I have connected up? Nope.....so that's ruled out.....and so I start my RMA process........first sent and the received back with a comment stating that the electrical board interface was replaced and "tests OK"....quote...heh....so I boot it up and within half an hour, the same artifacting comes back and I'm like "WHAT?!"...so I send it back stating, did you even fix this?? and I send them this link as evidence.....and they were like alright alright, I'll send it off, expect two to three weeks wait for it..and I said ok......a month later....got the second return and it commented "panel replaced"...so I guess the entire panel is replaced....so effectively I have a brand new monitor by now? Besides the case of it, which is still the same old one and that the interface board is replaced....and now I think I just saw a flash of white light and then back to normal in a split-second.........I will be on alert and attempting to take more evidence to see if this is the case....
If it turns out this is the case, what should I resort to? RMA a third time and hope I get *goodluck* in contrast to my username and received an non-defected unit? Heheehe...perhaps request for a completely brand new unit? or just a refund and get something else that DOES NOT have this defect?
Yes I've read all 12 pages of this thread and it appears that it is a ongoing defect that (no one?) is going to fixed...... If that is so, what other equivalent UHD monitor should I get in comparable quality, and price I suppose too, or less $$$ for better quality would be nice as well but I'm dreaming!
that are currently out there for consumers?
Geez, you're issue is significantly worse than mine! hahahaHello
I've had this monitor for over 6 months and I've had this issue since the purchase:
Same as some people mentioned, I also get sprit second lines and artifacts. They appear roughly 2-3 times a day. At first I thought the problem is with the cable supplied with the monitor and I bought this one as a replacement:
http://www.amazon.co.uk/Accell-B142C-010B-DisplayPort-Latching-Cable/dp/B0098HVXVQ/
Some of the reviews for this cable say it solved the artifacts problem. That is not my case unfortunately, I still get artifacts even though I pay them little mind.
"No signal detected" issue happens sometimes as well but it is rather rare.
The worse part can be seen in photo and video:
Code:https://dl.dropboxusercontent.com/u/2782785/benq.jpg
BQ:Code:https://vid.me/DgVo
Code:https://dl.dropboxusercontent.com/u/2782785/benq.mov
This happens roughly 2x a month (it happened 3 times in a single day yesterday, first time it happened so many times). I can switch to a different input when this happens (i tried having a macbook connected to the hdmi input. I tried restarting my PC but the problem persists. I have to turn the monitor off and on, only then does the problem disappear.
This bothers me more as I'm unsure if the monitor is failing.
I don't have an opportunity to test the monitor on a different PC under the same set of conditions - 4k resolution at 60Hz. Any ideas/recommendations? Has anyone encountered a similar issue?
The monitor is brilliant outside of these problems but I'm getting nervous when it acts this way.
BenQ BL3201PT - i7 3770k, GTX 680 (GV-N680D5-2GD-B), GA-Z77X-UD5H, Windows 10
