illram
- Sep 19, 2011
Trying to decide between these two monitors.
- BenQ is currently about $300 less than the Samsung,
- Sammy has HDMI 2.0, while the BenQ only has HDMI 1.4 (so I have to use displayport for 4k at 60hz). I like the convenience of HDMI, but not sure it is worth the extra money as this pretty much just means putting my headphones in the PC rather than the monitor, really. (And I might want to do that anyway).
- Both are IPS panels, although it was said on this forum that the BenQ has a nicer matte coating.
- I like the exterior design look of the Samsung more than the cheaper BenQ, but I don't know if I like it $300 more.
- Both have freesync according to PCMonitors review, but this is not a huge deal to me as I don't see myself using this. I do game, but I have a GTX 970 and my next purchase is likely going to be a 980ti, and I learned that annoyingly all of these "sync" solutions require displayport for now. Also just generally on a curmudgeonly level I feel like it is shitty that we have these proprietary solutions where you have to lock yourself into a certain GPU manufacturer for the life of your monitor if you want to take advantage of variable refresh rates.
- Both have low enough input lag that I feel confident I won't ever really notice. Correct me if I am wrong here.
- Both seem to have similar ratings in various reviews, generally.
Any suggestions? What am I missing? I'm leaning towards the cheaper BenQ, currently.
One thing I cannot really figure out--it seems both monitors are just average at doing 1080p or 1440. Anyone have experience with how either monitor handles lower resolutions, like a game in 1080p or 1440? For the foreseeable future I am primarily going to use this for office work at 4k (I need lots of info on the screen at once) but want the option to use this as a gaming monitor at 1080 or 1440 and not look crappy, at least until single card tech catches up to 4k resolution.
Is there a third option? I don't mind spending >$1,000 if it is a really good 32" 4K monitor.
Thanks!
Thanks!
