What do i need to get my PC to see they usb connectors on my monitor? I have it connected with the display por.t.
Plug in the USB cable?
Hey Astral Abyss, it looks like you've had the Benq BL3200PT and the Acer XB280HK. These are the two monitors I'm deciding on. I'll only be using it for gaming for a few months, then it will become a side monitor.
Which do you prefer?
Thanks
XB280, no contest, for gaming. It's literally miles ahead on my preference list. 4k gaming is amazing if you have the horsepower to run it properly and even then, g-sync fills in any dips in performance.
If you're not going to game on it much, well, the BL3200 has more real estate and you don't have the TN contrast shift if it's off-angle... 32" is hard to fit on a desk with another monitor though. I currently have my XB280 sitting next to my XB270. They fit easily next to each other on a small desk with just a slight V angle. There's no way I could do that if I still had a BL3200. Just something to think about... unless you mount it on an arm or something so you can swing it out of the way.
I use the monitor's hub for my wireless mouse receiver, my USB sticks, my external hard drives and my PC gamepad. I could use the ports of my computer case instead, but the monitor ports are closer and therefore more convenient.what do people actually do with USB connectors on a monitor? if the cable is needed, that means the cable is next to the user and you could just connect the damn thing to the cable. I fear missing the point here but have thought about this for past 10 years.
[X]eltic;1041185842 said:I use the monitor's hub for my wireless mouse receiver, my USB sticks, my external hard drives and my PC gamepad. I could use the ports of my computer case instead, but the monitor ports are closer and therefore more convenient.
I do seem to have a weird problem with my monitor's USB hub, though. Ever since having the BenQ BL3200PT, my computer occasionally crashes with a STOP 0x0000009F DRIVER POWER STATE FAILURE error.
Other people experienced crashes that are possibly related to the monitor's USB hub?
it would be cool if it didnt need a usb cable. that would make sense in some design
Yeah, it is very strange. I'm not 100 percent positive if the monitor's USB hub is the cause, but it sure looks like it, since my computer crashes only began after I bought the BenQ BL3200PT. Together with the fact that nusb3hub.sys is involved, it seems there's a weird compatibility issue between my USB 3.0 controller and the monitor's USB 3.0 hub. Maybe that's your problem as well. To investigate this, you have to download WinDbg and analyze the memory dump that's written to your hard drive after a BSOD. Here's a step by step guide how to do this:Damn! I've had three such crashes sofar and have been trying to figure out what caused them, I came up with possible shortcircuits in my keyboard (google yields some funny results) and other driver errors, but I lack the skills to properly analyse this type of errors. But your post suddenly makes this all clear!
I also use the BenQ's USB for my wireless mouse. It doesn't work properly when plugged into the back ports of the PC so the side USB ports of the monitor are a godsent.
This is not good news, I'd like to keep using the monitor's hub. But now at least I can experiment (since I don't really need USB3 speeds atm, I could try hooking it to the USB2 port of the PC and see if that makes a difference.)
Please keep posting other information on this, as will I!
You did connect the monitor's USB hub to your computer? The DisplayPort cable isn't enough, you have to connect the hub with a seperate cable. If you did, you don't need to download a driver for it in Windows, it should automatically be detected, together with the card reader.For some reason my monitor's usb ports arent working. I plugged in 4 different flash drives and none worked or lit up? If there maybe a driver im missing or something?
[X]eltic;1041187088 said:You did connect the monitor's USB hub to your computer? The DisplayPort cable isn't enough, you have to connect the hub with a seperate cable. If you did, you don't need to download a driver for it in Windows, it should automatically be detected, together with the card reader.
[X]eltic;1041186483 said:...analyze the memory dump that's written to your hard drive after a BSOD. Here's a step by step guide how to do this:
http://www.instructables.com/id/How-to-Analyze-a-BSOD-Crash-Dump/
If you also have a problem with your USB controller, I suggest you update your controller driver to the latest version. If possible, update the firmware of your USB controller too. I have a NEC/Renesas USB 3.0 controller (D720200F)....
Do none of you get bothered by this type of artifacts? I got mine last month and having trouble getting around this issue. It is not a minor artifact that only occurs with this particular LCD test, it happens a lot in other occasions when the pixels arranged in certain patterns. For example it will happen if you play some console emulators or DOS games with scanline filters turned on, or some older games that renders alpha blending with pixel skipping patterns. (Bugs me a lot when I'm playing those games, entire screen just suddenly flashes)
The fact that the entire screen flashes when switching to the pages like this http://www.gdargaud.net/Hack/DeadPixel/GreenMagenta.html makes me think it is some pretty serious defect with this monitor. First I thought it is my particular unit's problem, but after replaced and tested with two other units, and most people here seem to have the same problem, it looks like this model just has the problem inherently. I've never seen other monitors having this issue, so I don't know why this one does, maybe the issue with its firmware or circuit board or something, no idea...
Do you guys think this issue should be exposed more to the manufacturer or retailer, so it can maybe get fixed and people can be aware of this before buying it? Or does this seem common to you guys?
I seem to recall that for some older BenQ models, people have reported the same issue, and after disable the flickering-free technology(I know this is funny), the problem went away. Have you tried that?
Yes mine is flickering in the same area on Google Maps, but only when zoomed in at that particular distance. It is also flickering for me in Arma 3 if I'm in third person running over light colored ground.
It also flickers as discussed previously on http://www.gdargaud.net/Hack/DeadPixel/GreenMagenta.html when switching from the page. It causes an even stranger artifact when it's in a smaller window, where it completely changes the left and right side of the display outside of the window. It also flickers when the window is moved.
More flickering as well as when switching between the full size inversion tests from this page. It's more noticeable if you watch the taskbar while clicking next. http://www.lagom.nl/lcd-test/inversion.php#invpattern
I have a Gigabyte GTX 780, connected through Displayport. Maybe the graphics card is involved? But this does not happen to me with other monitors. What could this be, is it fixable?
I just tried scrolling around the same area on Google Earth that you've shown in your video and there's no flickering at all on my BL3200PT. The picture is nice and solid.
Have you tried connecting it to another PC?
I sent mine back a couple days ago as I cant justify the vertical banding at £500. I actually genuinely miss it already. 1440p @ 32" is very comfortable and the lack of IPS glow makes this monitor much more attractive to me than any of the 27" offerings. The build quality is also very impressive - I always had BenQ in my mind as a more budget brand but I was highly incorrect there.
I really hope AUO phase out the banding problem as the process matures so I can buy another![]()
Something strange going on here; That page doesn't cause flickering on my BL3200PT (well, the cross-hatch pattern itself flickers when moved, but all LCDs do that. The rest of the screen is fine).http://www.gdargaud.net/Hack/DeadPixel/GreenMagenta.html
to test. Dragging this window causes the flickering white across the screen exactly as in Google
But if I drag the window over to my second monitor (a 30" Samsung 305t+) I do get flickering and strange interference patterns on the Samsung.
I'm currently using an old 24" Samsung TN (245B), that I have had for about 7 years. I see flickering on all of these tests, but I have literally never noticed this during the past 7 years. I play lots of games (including BF3 and Arma 3) and never noticed it in game.
I have a GTX 670. Anyone have issues using an AMD card?
BTW, is there really need to hunt for some obscure bugs that need special methodology only to notice? If those special tests help find/check/notice something that can be seen in common games/common work programs/common website browsing, it's good. But if they show some minor glitches seen only in them will that really be end of world and marking monitor as bad/unusable?
Using a Radeon 290 here.I have a GTX 670. Anyone have issues using an AMD card?
