My understanding is that the Acer is "better" calibrated out of box for office use and watching movies?
From post #872. I recall you asking questions I answered in previous posts before, please read posts more carefully.
NCX said:I just double checked TFT Central's review, and the Acer has better color presets (specifically the gamma since the BenQ suffers from strong black crush and when using the preset, Gamma 3 setting) while the BenQ's gamma needs to be change from 3 to 1. Their presets accuracy is very similar once the BenQ's setting is change, but the Acer should be slightly better even after the BenQ's gamma setting is changed from 3 to 1.
Hold the E button when the monitor is powered on and an F should appear in the top right of the menu, hit the < key to get down to the OD text and reduce it while looking at the Test UFO Ghosting Test until the overshoot ghosting (example=BL2710PT's AMA Premium) disappears or is barely visible.
If the B326HUL's OD is set to 9, 4 & 5 should offer a nice balance between fast pixel transitions and minimal overshoot ghosting.
