swatbat said:The older 1 ghz cores were more like 450-500 mhz p3's because of the bad floating point preformance.
Eva_Unit_0 said:yeah that was the older ones though. the old C3's only ran a 1/2 clockspeed FPU so their performance in anything floating-point was pretty poor...about a 500mhz in this case. But the latest gen of via cpu's run a full speed FPU and also use SSE/2/3 instructions to further help performance.
swatbat said:Yea I couldn't think of what the newer cores were called and don't remember their preformace. What would you think a newer one based of the other cores would do? Maybe like a p3 800?
Yeah, it is one motherboard that has the processor and all the peripherals built onto it. Very tiny and runs very cool, makes for a good htpc or linux box.serbiaNem said:Can you actually build a pc with a via chip?
