This morning I booted up my computer. I think I walked away while it started. I came back and I logged in and I can't remember exactly what happened but eventually the monitor lost an input from the computer and I believe the computer shut off on its own. I had the computer on for at the most, 5 minutes. I then turn the computer back on, it seems to be having some trouble, the fans are on full blast (btw there's snow outside, it shouldn't be that warm in the computers case). Eventually I smell burning. I try switching to the bottom graphics card, since I have crossfire. I get the computer to successfully turn on and I can use the computer normally. I notice later that I can't get sound out of the soundcard. I switched back to onboard sound and its working.
Possible causes:
mobo
power supply
surge protector (I live in the Northeast where we lost power. I've been running it on a generator since sunday and we got power back on tuesday however I feel that the chance is slim since I used it all day yesterday on normal power and everything was fine.
I think its possible that the soundcard burned because of the gpu heat, however the card that is still working was between the faulty card and the soundcard.
I built this system in June. I did overclock it a couple months ago but all the clocks are stable.
I'm really clueless and I need your guys expert help
Btw: I bought the graphics card for 150 from Bestbuy when they first came out. Can I exchange it there? I'm probably going to have to go through the gpu make. If I can't fix the soundcard, I can't do anything with that. It's a couple years old .
Possible causes:
mobo
power supply
