Wolverine2349
- May 30, 2016
Which of these 4 cases would you pick if you had to choose?
For a 12900KS build cooled by a Noctua NH-D15S with dual 120/140mm fans and a Asus Tuf GeForce RTX 3090. No HDDS/Optical disc drives
Which case would provide best balance between cooling and relatively low noise for that setup out of all of them??
And which case is best for sound dampening to drown out coil whine and vibrations while still providing good/decent airflow??
I am leaning towards the Silent Base 802 it seems good with airflow config front mesh with a foamed top and side panel.
