HardOCP News
[H] News
- Dec 31, 1969
If you are looking for a high performance CPU cooler for your next system build, the crew at Overclockers Club suggest taking a long hard look at the be Quiet Dark Rock TF.
The Dark Rock TF is perfect for your daily driver or an overclocked gaming rig. It easily tackled the heat generated from overclocking in my Phanteks Enthoo Primo test case, which is a very large case with plenty of airflow. I would expect to add a couple degrees for a small case with less airflow. Regardless, the Dark Rock TF proved that it is a worthy opponent in the battle against heat.
