Batch rename of folders (append with suffix)
Discussion in 'General Software' started by rhouck, Jan 23, 2011.
  1. rhouck
    rhouck 2[H]4U
    3,598
    Apr 15, 2002
    I am looking for a solution to batch rename folders from "Name" to "Name [FLAC]".
    My music is currently divided into two main folders: one for lossless (flac) files and one for all other (mainly mp3). I would like to consolidate them but would like to make it easy to see from a folder level which albums are lossless.
    The format is \\Quality\Artist\Album
    For example:
    \\Music-Lossless\A Perfect Circle\Mer de Noms
    \\Music\A Perfect Circle\Thirteenth Step
    I would like to have all the "Album" folders renamed to "Album [FLAC]".
    So "\\Music-Lossless\A Perfect Circle\Mer de Noms [FLAC]" would be the result.
    There are ~500 Artists in my Lossless folder, each with various Albums as subdirectories, thus the desire to have this done as a batch rename. It would need to be recursive down one folder level (as I'd prefer to not have to go artist-by-artist).
    Suggestions on programs or command line way to do this?
  2. devil22
    devil22 2[H]4U
    3,834
    Jan 1, 2003
    Here's a PowerShell script that does it, PowerShell is included in Windows 7, the first time you run PowerShell, you need to run it as Admin and run the command "Set-executionpolicy RemoteSigned" to enable you to run scripts. Save it as 'batchrename.ps1' and run it by typing '.\batchrename.ps1 [directory of Music-Lossless]' so for example '.\batchrename.ps1 c:\users\bob\music\music-lossless'
    Code:
    if ($args.count -ne 1) {echo "Requires 1 argument. Exiting."; exit}
    $musicdir=$args[0]
    if ((get-item -ea 0 $musicdir).exists -eq $false) {echo "$musicdir does not exist. Exiting.";exit}
    $artists=(dir (get-item $musicdir).fullname | ?{$_.mode -match "d"})
    foreach ($artist in $artists)
        $albums = (dir $artist.fullname | ?{$_.mode -match "d"})
        foreach ($album in $albums)
            mv -literalpath $album.fullname "$($album.fullname) [FLAC]"
  3. phide
    phide [H]ard as it Gets
    16,695
    Jun 11, 2004
  4. rhouck
    rhouck 2[H]4U
    3,598
    Apr 15, 2002
    Thanks for the help, I believe this will work perfectly for my needs.
  5. zero2dash
    zero2dash [H]ardness Supreme
    6,081
    Oct 23, 2007
    +1 I love ReNamer
