Basic case for i8700k and other parts
Discussion in 'Cases & Case Modding' started by vidoprof, Jul 8, 2018.
  1. vidoprof
    vidoprof Limp Gawd
    457
    May 3, 2007
    I am building I THINK a rig with the following.
    i8700k - super mild OC
    ATX MB (not sure which yet, still researching) will be asking in MOBO section soon.
    Fan to go with CPU
    1060 GPU
    (2) m.2 hds
    32GB ram
    (1) 4tb WD Black drive
    550-650W PS (I don't think I need this much, but rather have it and spend the extra $20 - $40 on it
    Don't need RGB lighting. Don't need to see anything. Preferably black.
    Any thoughts on a simple nice black case with decent cooling?
    Thanks
    Ryan G
  2. vidoprof
    vidoprof Limp Gawd
    457
    May 3, 2007
    Yep... ME AGAIN!! :) I am a pretty basic guy.. Just something that is relatively cheap and don't need window or RGB lighting.. Just something to hold the parts and black preferably. I would like it to have the ability to stay cool as well.
    THanks
    Ryan G
  3. drklu
    drklu 2[H]4U
    2,107
    Jul 15, 2013
    NcaseM1 would work nicely here. Not the cheapest case but they really easy to build in and fit all your parts in a nice small package. You would need to change to a SFX PSU and itx mobo though.
  4. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,658
    Apr 5, 2016
    Corsair's budget-oriented line are no-frills, well built, and inexpensive. I've enjoyed my builds in them.
    AlphaQup and pendragon1 like this.
  5. vidoprof
    vidoprof Limp Gawd
    457
    May 3, 2007
    Any particular one you like better? Which is their budget line?
    Thanks
    Ryan G
  6. VanGoghComplex
    1,658
    Apr 5, 2016
    I used and enjoyed the Carbide 200r and 300r. Their model lineups have probably changed a bit in the interim, but the Carbide series should be worth a look.
  7. AORUS
    AORUS Limp Gawd
    413
    Oct 31, 2017
    Why buy at tower case! just build one out of wood and stick a fan on top job done then put it under your desk.
  8. viivo
    viivo Gawd
    1,014
    Sep 7, 2005
    Fractal Design Define S - Sleek, solid, and silent, plus it often goes on sale and can be found for around $50. I went from a full tower to this and have not missed the extra space, even with 280mm and 120mm radiators. The soundproofing material isn't a gimmick - it makes a noticeable difference.
  9. vick1000
    vick1000 [H]ard|Gawd
    1,911
    Sep 15, 2007
    Define R6 gets my vote, best I have ever used. I had a Define S as well, but it was a little cramped and not as versatile.
    Denpepe likes this.
