hey guys
a while ago i upgraded to a 64 bit machine.
i bought an amd64 3200 and a msi k8n neo platinum board and transfered my existing components onto this board. Anyways, after my upgrade i found out that my system was unstable because of my ram (ocz pc3200 dual channel kit) so i replaced it with one stick of 512 kingston hyperx ram. THIS is when i started to get some serious problems. my system started to crash from doing ANYTHING. at first it took more intense applications to crash the system like doom3...then even using MS word or surfing the internet got really frustrating from all the crashes. so after countless hours of scouring the net for help, i decided to suck it up and get it serviced by someone. They told me i had a bad board, so they sent it away for me and now i have a new one(maybe some board just fixed..i dunno). so i finished putting my system back together just a few hours ago...and had no problems until.....i was doing homework. the blue screen of death that ive gotten to know all-so-well shows up again and tells me i have a "bad pool header"(which means nothing to me). So with my mainboard ruled out, what can be the cause of this problem and what can i do to fix it? sorry i made this msg a little long but i thought giving you the past of my system might help when it comes to determing whats wrong.
thanks alot for all your time and i appriciate any sort of help or insite.
elvis
my system:
amd64 3200
512 kingston hyperx
geforce 5600
elvis
my system:
amd64 3200
512 kingston hyperx
geforce 5600
