I recently built a new system that has had inexplicable network problems. Often firefox (1.5.05?) won't load websites while IE will load just fine. Other times it is reversed. My aim randomly disconnects and reconnects. There is no problem with my cable connection (3.0 mbps running through a linksys wireless b router connected to my computer via cat5). The whole time that I'm having these web problems, limewire can be running (downloading/uploading) and report a decent connection. Usually a reboot is required to solve the issue. Is there a way (or program) to solve my little problem, because it's terribly inconvenient when I need to do some real work. I run the included nvidia firewall (came with mobo). Should that be disabled?
B
Specs:
P D 805
1 GB PC667
ECS C19-A
ATI x800 xl pci-e
160 GB SATAII WD
80 GB PATA WD
16x BenQ DVDRW
SB Audigy
Win XP Pro
B
Specs:
P D 805
1 GB PC667
ECS C19-A
ATI x800 xl pci-e
160 GB SATAII WD
80 GB PATA WD
16x BenQ DVDRW
SB Audigy
Win XP Pro
