Axman
- Jul 13, 2005
I bought an MSI FM2-A75IA-E53 for an HTCP/file server earlier this year and it wouldn't boot, POST, or beep. I sent it back to Newegg, and the replacement mobo was the same.
I got frustrated, thinking that somehow it was not compatible with the AMD A6-5400K APU, so I went out and bought an ASRock FM2175M-ITX to see how that worked.
It powered up and installed Windows, although it wouldn't detect the SSD, which also had problems with two other computers. I think it just doesn't work, but I mention it because it shows up in the other computer's BIOS/UEFI, but it does not with my current ASRock FM2175M-ITX.
It ran, but suspend didn't work and it would occasionally crash so hard that it didn't have time to blue screen.
I ran MEMTEST on it and it was a wall of red. So I took it back to the Microcenter and asked if I could not just exchange the RAM (Crucial Ballistics), but test it in their service center first. The first pair of RAM I tested sprouted failures right away, so I tried a third set of RAM. It was late, so I was pushing closing time, and went home before the test completed. Still, it was somewhat promising as it didn't fail in the five minutes or so I had to test it.
But today I ran it again after discovering that the USB 3 plugs weren't working; I thought maybe the original bad memory build was corrupt. Being a fresh install, I just grabbed my media and began to reinstall Windows (7 Premium x64). I get to the copying files portion and it BSODs:
STOP: 0x00000050
PAGE_FAULT_IN_NONPAGED_AREA
This is a bad RAM code. I ran MEMTEST and it came up all failing again, no surprises. After that, I tried again, and got some other driver-related BSODs.
Three motherboards, three pairs of RAM, flaky SSD: While it's clearly throwing memory faults, I can't help but think the problem may be the APU.
This would be the first ever CPU I've had that sorta-worked. I've never seen one do anything other than run or not run. But it's common to all the hardware configs. Anyone else ever get a processor that's shitty but OK enough to boot (and sometimes install and run an OS)?
What would you do in my situation?
STOP: 0x00000050
