Bad bigadv 6900(32,24,41)
amdgamer
It looks like there is another bad work unit floating around. My system ran this a couple of times and EUE's right at 0% every time. If a work unit fails, why in the HELL does the work server send the same damn WU out?
amdgamer
I deleted the work directory, the queue.dat, and even changed machine ID and it just sent the damn same WU out again only to EUE again...........
sirmonkey1985
[H]ard|DCer of the Month - July 2010
because thats the way the system is designed. just because it fails on one system it may not fail on the other. yes there are WU's that are completely bad and will fail on any system but thats why they need to be reported on the FF so they can be removed from the WS.
jebo_4jc
[H]ard|DCer of the Month - April 2011
Did it give you fahcore.exe errors?
Posted via Mobile Device
jebo_4jc
OOOHHHH
For the past 2 days I've been thinking my SR2 was totally unstable. I think this unit might be the problem.
amdgamer
I had company last night, so didn't have the time. I happened to be walking by the guest bed room when I noticed that folding2 had crashed, and had apparantly crashed 2 times on the same work unit.
who says?
You're probably the one that broke the WU.....:rolleyes:
LOL.
