Hi all,
I inserted a file into a Power Point file and have it set to play across all slides.
In Presentation Mode the audio file runs for the entire duration appropriately (good!)
However, when I Save As to Windows Media Video the audio gets cut-off at exactly 57 seconds.
In Windows Explorer when I right-click the file and go to Properties > Details, the duration = 00:01:07 (which is correct). I have played this same MP3 in Windows Media Player and it plays the entire 67 seconds perfectly.
Upon further investigation in Power Point, I select the audio file on Slide 1, open the Animation Pane, click the drop-down and go to Timing, and then select the Audio Settings tab -- here the Total Playing Time = "00:57". (WRONG)
Also, when the audio file is selected on Slide 1, I can go to Playback in the top ribbon and then open the "Trim Audio" button and see that the full duration listed is 00:56:994. (WRONG).
I am flabbergasted.
Anyone run into this before and have a fix??
I'm using MSFT Office 2010.
I am flabbergasted.
