thesmokingman
- Nov 22, 2008
Backbreaker, because it's really getting too heavy that it hurts to move. And the name kind of goes with the whole Threadripper thing. I don't usually do build threads because I tend to build them too quickly but this one is going to take a little longer than usual and I didn't want to keep hijacking other peoples threads.
The goal is to combine my htpc/server and daily rig into one machine that does everything I need in one package. What that essentially means is hand down my relidded 6700k to my son and sell off the old 3930k server. I think I can hold onto this TR build for a good many years, crosses fingers.
Main parts:
cpu - Threadripper 1950x
mb - Asus Zenith Extreme *Note the Zenith's armor does not clear mb tray grommets bending board (fix is to remove grommets)
ram - G.Skill TridentZ 3733mhz 4x8gb
gpu - Nvidia Titan X Pascal
m.2 - Samsung 960 EVO 500gb m.2
ssd - SanDisk Ultra II 960gb SSD x2
psu - EVGA 1300G2
case - ThermalTake Core X9
raid - Highpoint RocketRaid 3530 12port RAID
raid - Adaptec 5805z 8 port RAID
disk - Seagate 3TB x12 = RAID 6 27TB
disk - Seagate 10TB Ironwolf, Seagate 6TB x2
disk - WD 8TB Red x2
lcd - BenQ XL2420TE x3, surround 144hz
Cooling parts:
cpu - EK Threadripper EVO waterblock
gpu - EK Titan X waterblock
res - EK RES X2 150
pump - Swiftech MCP35X w/ Acool metal sinked body
rad - XSPC RX480mm
rad - TFC Xchanger 480mm
fan - Gentle Typhoon AP15
fan - Sunbeam Rheosmart 6
The stock Core X9 while flexible is astonishingly weak on storage especially for such a large cube type case. The thing only came with 9 drive bays total. I really cannot comprehend the lack of foresight by TT. Thus on this build storage was the key to making this case work for me. Cooling wise I have a pair of EK Coolstream XE480's but as I got down to it, I was just too lazy to tear them out of the Enthoo Primo they are currently residing in, which also happens to be the pc I'm typing on. I'll get around to swapping the rads in 2018, maybe. I figure I am in no hurry because 960mm of good but old rads is still more than enough for the load.
The first thing I did was start modding the X9 to hold 20 drives while still retaining the tray system that TT uses. For this I found the Rosewill 4x3.5in server drive cages. They come with a junk 120mm fan in a somewhat decent looking grill/frame. But I didn't need the grill either. I ordered 5 of these and took off everything attached to them. I measured, drilled, used some 6/32 screw/nut sets to attach them to the existing TT drive trays. A quick coat of flat black and voila.
https://smile.amazon.com/gp/product/B005FHHOXE/
Main parts:
psu - EVGA 1300G2
Cooling parts:
res - EK RES X2 150
rad - XSPC RX480mm
Test fitting Rosewill cages
Painted black and mounted
PSU side of case with pump mounted and last cage
Just got the board and I had to see it in there
Test fitting drives and drive cabling
