harsaphes
- Aug 29, 2005
Hey all. OK, here goes...
I have a Samsung JS9500 set and a Denon X2200W AVR and PS4. Everything works correctly. I recently bought the game Zero Dawn which has an HDR setting. After turning all the setting correctly on the TV and PS4 I was able to select the HDR in game (previously greyed out).
Everything looked terrible and I turned the selection off. After hours of fiddling with settings I connected the PS4 directly to the connect box of the set. Voila! HDR goodness, but now I'm confused how to setup my audio.
Whew...sorry if this is so long....
My AVR is connected to the set using ARC, so thats how my sound travels. Once the PS4 was disconnected from it, it had no sound.
The Samsung connect box has an optical out as does the PS4.
The Denon has optical in (i'm pretty sure)
Because the PS4 is no longer connected to the AVR it is not assigned when selecting inputs.
I'm assuming I do optical out from the PS4 to AVR but because it's not assigned any longer how would I set it up?
Thanks.
Thanks.
