Just received my Gigabyte/Auros 1080ti Xtreme card yesterday. Clean install of windows, updated all drivers and the card is unstable at stock settings. I could not even run Heaven 4.0 without it exiting out the program. Same thing with Firestrike..it tells me the user cancelled the test.
So I tried playing BF 1 and it also crashes after loading a map. This was when the card was in OC mode which increases the GPU clock to 1746.
If I set it to "Game" mode where the gpu clock is 1721 I can run benches and play my games without issues. Also if I underclock it. As soon as I increase the GPU clock close to their "OC" mode clocks its unstable.
I also tried increasing the voltage all the way and setting power target to 120 to try the "OC" mode clock and same thing, crashes on benches.
Curious, anyone else get this card? Thinking of doing an RMA from Newegg. Too bad its replacement only, because they are out of stock.
