Scott Mueller
- Feb 9, 2018
Anybody know of a good reservoir/pump combo that has RGB lighting that syncs with ASUS motherboards (using Aura)? This will be in a Thermaltake Core P5 chassis. I found this Enermax that looks great, 400ml, and much less expensive than others. Unfortunately, it looks like commenters are complaining it leaks and has other problems
https://www.newegg.com/Product/Product.aspx?Item=N82E16835214078
https://www.amazon.com/Enermax-NEOChanger-Synchronisable-Motherboard-ELC-NC200RGB/dp/B071VNMBVM
Thermaltake's RGB reservoir/pump should work perfect in a Thermaltake chassis, but it doesn't support Aura:
http://www.thermaltake.com/Liquid_C...ir/C_00003126/Pacific_PR22_D5_Plus/design.htm
I'll go with that one if I can't find any good reservoir/pump combos with Aura... or if someone convinces me to not listen to those negative reviews on the Enermax .
