Background (you may just skip to the question at the end if you wish)
I have my HTPC (see sig) connected to my reciever through HDMI for audio and video. This is the primary use, and it works very well. However, from time to time, I like to play my X360, which is also hooked up through HDMI, but listen to music from my computer hooked up to the reciever using the rear anolog audio out (green circle). This also works well, however I have to select the different output in the audio manger in windows.
This is where the problem lies. I then have to hook up the mouse, and change the display to show my computer and take the steps necessary to change the audio output. Then, if I want to watch a movie in full 7.1, I have to switch it back.
So the question is: Is there any way to have the audio sent through both outputs at the same time?
I use WMC for everything on this HTPC, which is why I would want audio sent to both outputs all the time. Which one I use would be based on the input I select at the reciever.
