ATW polarizer monitors
dopple
i've heard a lot of praise about the 2490wuxi nec due to its 8bit ips panel and also the a-tw polariser i wonder if there are any lcds currently available with that particular spec since wuxi is not being manufactured anymore.
thanks
Godmachine
Bottom line , nope. A-TW Polarizer's have been out of production for years and years. You can either find a 2490wuxi or you're screwed.
tk-don
If you want monitors with larger gamuts than sRGB and A-TW, a few options still exist:
LG W2420R
HP LP2480ZX
Quato IP240-EX
i believe all are still in production, but I may be wrong.
For A-TW and sRGB: None.
dopple
hp suggestion looks good except its $2k wuxi is too bright though even at its lowest settings. ill probably have to give up this chain of thinking.
I think it makes more sense to bump this thread than to make a new one...
Based on observations, I think my rMBP may have an a-tw polarizer -- what do you guys think?
Retina MacBook pro left, NEC 20WMGX2 right. My Mac also has the slight red/green hues off angle that's typical of a-tw monitors.
If it does indeed have an a-tw film, I wonder if apple will include one in any of the ACD updates in the future
